Old 06-17-2015, 02:22 AM   #29 (permalink)
bondvagabond
vandle - '93 Ford E-350 Xlt
Now we are getting somewhere. I could see where an aftermarket turbo could be different than a stock. The na 6.9 and 7.3 idi can only handle about 10 psi boost before starting to pop headgaskets from what I've heard. What boost are you running? Is your 6.5 electronic or full mechanical?
Also, someone familiar with these idi's can you confirm that the transmission control modual only controls the trans? The zf6 is not electric except for neutral and reverse sensors. So hopefully I can pull and sell my good e40d control modual if it does nothing else. I know my van has no ECM for the motor.
2007 Silverado 3500 classic duramax diesel, Allison 6 speed auto, extracab long bed. Doing head gaskets, will probably do econo tune and aero mods next.
Mad max would have driven a metro
