Old 06-17-2015, 09:10 PM   #112 (permalink)
Ardent
This simulates 500 rpm increments of 0-6000 rpm. The same program will be run once the motor is installed on the car to measure the load of the water pump at the different rpms.
Will you then reference pump speed to coolant temperature?
