Old 06-18-2015, 08:52 AM   #115 (permalink)
Daox
Originally Posted by Ardent View Post
Will you then reference pump speed to coolant temperature?
Yep. After I do the testing, I will load up a new program into the arduino that'll control the pump speed based off of coolant temperature and engine load. It also will pay attention to if the engine is running or not, so the pump stays running (but slower) during EOC so I have heat in winter with the engine off, yay.
I talked about the program and its behavior earlier in this thread.
