There are more pics on the Silver build thread. I still have the upper grill block with the ambient air sensor snorkel attached. I'll put the lower one back on when it gets back below the 80s again. I doubled the air hole access and was still smelling hot plastic. I got worried that the headers might not be getting enough air moving around them causing the plastic belly pans and tunnel to suffer too much. Also, since I'm using the AC often I want to be able have enough fresh cool air moving across the condensor to pulse the inside air temp down in preperation for my next hill climb or stop light.
