Old 06-19-2015, 01:36 PM   #108 (permalink)
sidecar
Not really. I just looked on car-part.com. A Prius trans (of which there are TONS) can be found for $100. A new refurbished battery from a Prius is only around $1k. A few cells to change out the bad ones? Likely a LOT less.
well I reckon thats crap
the trans is a take forever job as you you have to take half the car apart
trans remove/install
and batteries are noticeably more expensive as a lot of gen IIs are nearing 200k and demand is up. If there are $100 batteries out there, then like this car its a wreck Gen II batteries -- a worrisome trend | PriusChat
