Old 06-19-2015, 05:23 PM   #6 (permalink)
sheepdog 44
i'm having some reservations abut doing this. Do you think it's possible to learn enough in one day? Could you guys give me some tips?
What i worry about is getting it into 2nd from 3rd double clutching into nuetral inbetween. The Ima battery is toast so I won't have any instant restart luxuries.
I don't quite understand the best way to get it to stop at a stop light or a toll booth- what exactly i'm supposed to do.
Once i have good momentum going can i shift with the clutch and not worry about stalling the engine?
I had one lesson a while back where i only took it to 40mph that lasted a half an hour.
This is a 2000 honda insight. wht rpm should i shift and what mph between gears going up and down. i need to create a cheat sheet.
I try to be helpful. I'm not an expert.
