Originally Posted by RedDevil
But I like the first double white circle design best, so much so that I may want to do that (with your permission) on my Insight.
Go for it! make sure to post pictures if and when you do!
Hope the rear does not sag too much when loaded; it would disturb the cirvle That would be less critical if the lower edge for the skirts was around axle height. They look a bit low now.
That's an interesting point. I'll definitely have to test this once I've got some prototypes to play around with.
