Here is a view of the whole engine compartment
I did need to move around some of the large wire connectors that were in front of the old battery try, but only had to modify and lengthen the battery main ground wire for the installation.
The orange box you see that surrounds the battery is supplied from the factory as an armor to prevent the battery from expanding under high heat conditions. I just used it to attach all of the new battery mounts.
