Update: Even setting it a little bit lean failed miserably lol. AFRs quickly dropped really low, even with the learning limits changed. Seems like lean burn isn't going to happen :/ I'm going to just do what I can and set the CL fueling target tables to slightly lean so the engine tends to run slightly lean rather than slightly rich, then set more cells to 14.7 in the primary map.
Also, I realized why overrun mass airflow target is the way it is. Today I was driving around with my map and I realized that below 2000rpm I set the target airflow so high that the revs would hang for multiple seconds in low gears because DFCO is disabled -_-
I just noticed that the minimum value you can put into the VVT table is -40 deg. I'm cranking it to -15 first to see if it'll actually do it.
