Old 06-23-2015, 11:05 AM   #42 (permalink)
Sven7
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Got started on the tonneau, since I don't have any time to lose here. (It took two 4x8's of OSB, at $10/piece)
I've got four boards screwed to the underside to prevent it from sliding more than 10-15mm. Later added a couple 1-1/2" holes on the rear edge to help me slide it on/off, although it is extremely unwieldy.
I have been wondering how to secure it down. I have two stake pockets at the front top corners of the bed, and two die-down hooks at the rear lower corners. I think I will drill a few more 1-1/2" holes, and then a few in a line horizontally between them. Then I can throw a good, thick bungee cord through each hole, hook it on the stake pocket/tie-down, pull it taut and stretch it to the furthest possible hole. This should pull the (already heavy) tonneau to the bed enough to keep it from moving or making noise.
The Following User Says Thank You to Sven7 For This Useful Post:
aerohead (06-23-2015)
