Old 06-23-2015, 04:08 PM   #43 (permalink)
aerohead
to secure
On the T-100,Gilkison (AeroStealth) put 2X3 pieces down the stake holes,flush with the rail tops,then used carriage bolts through existing holes on the bed sides to secure those.Then the bedcover was through-drilled,and screws/fender washers were attached down into the 2X3 attach points.They're still in there,20-years later!
Eye-bolts mounted upside-down at the rear could anchor turn-buckles at the top,and into existing loops below.
