Old 06-23-2015, 08:31 PM   #34 (permalink)
bondvagabond
vandle - '93 Ford E-350 Xlt
Made some good progress today:
Got manual brake mc mounted
Auto trans neutral switch bypassed
Brake pedal mocked up and tack welded with correct pedal ratio to make up for loss of booster
Pilot holes drilled at 4 corners of square hole for clutch mc
Trans output flange nut torqued to 247 lb ft
Slip yoke splines greased
Fabbed new brake mc push rod
Just 7 more things on my to do list, and my shimmed out auto starter worked great. Was worried I'd have to spend $140 for a manual one.
2007 Silverado 3500 classic duramax diesel, Allison 6 speed auto, extracab long bed. Doing head gaskets, will probably do econo tune and aero mods next.
Mad max would have driven a metro
