Old 06-24-2015, 12:37 AM   #6 (permalink)
Dean in Milwaukee
The 2015's only come with the 2.5 4 cylinder, no 6 is available. It does get up and go if you want though, 184 hp and 3100 lbs is quite decent.
The econ gauge maxes at 99 mpg, but it does that every time the throttle is shut at any speed over 10 mph.
As is, setting the cruise at 60 or so causes the econ gauge to sit in the 46-48 range, again so long as there are no hills or significant headwinds.
The only mod I may do would be a partial grill block, but I would have to make it invisible so the Missus won't mind.
