The rear is a bit more time consuming and is adjusted by removing (or adding shims) under the mounts for the radius rods:
I have an idea that's bumping around - but this will do for now as Centurion has another appearance to get to!
~CrazyJerry
[/B][/QUOTE]
You need to get some adjustable rear radius arms I think They are pretty handy for doing the alignment.
Adjustable Rear Radius Arms, pair
for the Spitfire Mk1, 2, 3, 4 and 1500 models
Available for Spitfire Mk1,2,3 or 4 (Short drive shaft)
or Spitfire 1500 (Long drive shaft)
£ 118.00 per pair
You can get them here =
New products from JIGSAW
