Old 06-24-2015, 11:19 PM   #46 (permalink)
oil pan 4
Originally Posted by bondvagabond View Post
About the only problem I have heard of with the pre powerstroke 7.3 na idi's is popping head gaskets above 10psi boost, or 15psi boost with arp head studs or 20 psi boost with studs and girdle.
That is not caused by boost pressure alone. When these engines are said to die from ____ level of boost, this largely due to people using too small of a turbo, running high drive pressure, scorching intake air temperatures and no intercooler.
I see up to 20psi of boost when I go back down to sea level. I have a 6.5L block and OE style torque to yield head bolts.
But I run 2 grossly over sized turbos and the boost is intercooled. So drive pressures are much lower than someone trying to force 15psi through a GMx series turbo, and running drive pressure to boost pressure ratios of up to almost 4:1 (40 to 50 psi of drive pressure to make 10 psi of boost pressure).
