Old 07-28-2008, 04:57 PM   #5 (permalink)
metromizer
You might want to check that thermostat as well. Make sure someone didn't remove it. Beside the obvious (helps get the engine up to operating temp quicker for better FE) thermostats act as a controlled restriction in the cooling system. They actually slow the the coolant flow for better heat transfer on a hot day.
