Here are some more pictures of the belly pan based on some of the questions from pervious posts.
Here is some detail where the front spoiler attaches to the belly pan
Here is how the belly pan is attached to the rocker panels between the wheels with the 1X1 inch square rod and also where the side skirts attach to the outside edge of the 1X1
This is the access panel to change the oil without removing the belly pan
I added a 2X2 inch angle to each of the side jacking points to make sure we can jack the car up safely
