Old 06-26-2015, 12:43 AM   #13 (permalink)
2000mc
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
I probably haven't thought this through enough but...
How about copper tubing, a pump - like http://www.amazon.com/gp/aw/d/B007XH...XN542E2NG370JE but not pressurized, just filled with water. If you turn off the pump on a longer drive, let it boil, then you just fill it up before the next time you expect it to work. Maybe there would be a more elaborate way of having a reservoir which would refill the system with the circulation pump the next time it's turned on, without having the reservior be part of the circulation circuit.
Edit: Maybe position the pump and reservoir as low as possible, so that with the pump off, water would drain back to the reservior, away from the heat exchangers. Sizing the reservior to be running near empty while the pump is on / system circulating
The Following 3 Users Say Thank You to 2000mc For This Useful Post:
Daox (06-26-2015), deejaaa (06-26-2015), Isaac Zackary (06-26-2015)
