Old 06-26-2015, 10:09 AM   #19 (permalink)
SDMCF
A second second coolant loop with gravity drain back that is open to the atmosphere.
If the reservoir were insulated it could be used to retain some heat from one session to the next, reducing warm-up times still further. You might need to run the pump for a short time at the end of a trip (perhaps on the last few km of a trip) to get the best out of that configuration.
The Following User Says Thank You to SDMCF For This Useful Post:
Daox (06-26-2015)
