Old 06-26-2015, 10:37 AM   #6 (permalink)
deejaaa
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
Originally Posted by vasonline View Post
.... one steel wheel left: the donut.
The donut is around 8 kg. But it would appear it's quite difficult to find
a "light weight" donut with bolt pattern 4x100 and 15" (would 14" be acceptable? when
you have 15" wheels)....
measure if there is 1/2" space between brake parts with the 15" on. if so, a 14 probably will fit. just to confirm, use any 14", even if not correct bolt pattern and hold it on with other wheel removed to check clearance.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
