Originally Posted by RedDevil
Hi vasonline, welcome!
If I may ask, where did you orI'm looking for options and the 12V swap would serve to test the waters.
Does it have a BMS?
Hi,
This is the manufacturer:
hi-genius.com (I cannot post links) then "car startings"
Yes, it indeed has a BMS. it will cut off when you go below a safety
voltage.
You can press a 'reset on/off' button to activate (and recharge)
the battery again. But in normal use I do not need to touch the on/off button.
It is compatible with the lead acid charge voltage.
Thanks for the replies
Ditching the spare altogether is also an option, with a small compressor
Maybe I should look for a 14" Honda insight 1st generation donut?
I'm not quite sure If I can find that in Europe...
