Old 06-26-2015, 09:37 PM   #17 (permalink)
slowmover
90 day: 19.36 mpg (US)
Clearance on mine, body to road, is 17". Walls are radiused down into full belly pan. Only axles are exposed. Comparatively long leaf springs with fairly sophisticated equalizer. Full set of shock absorbers. Cross members from spring attach points.
A representative mid 20' footer Shasta Flyte was 23". No pan. Everything exposed. No shocks, short springs and standard steel equalizer. No crossmember. Greater resistance, IOW, to crosswind pressures, not to mention larger volume of air under trailer in any situation.
The Following 2 Users Say Thank You to slowmover For This Useful Post:
aerohead (06-27-2015), BamZipPow (06-27-2015)
