Old 07-28-2008, 05:12 PM   #13 (permalink)
ATaylorRacing
38 time NHRA/IHRA Champ
ATaylorRacing's Avatar
Here is my take...with 35 years of drag racing street driven cars:
If your car does not require premium and the timing is stock you can actually get worse mpg with higher octane, The higher the octane, the slower it burns....a lot of cars drag raced with premium fuel will actually run slower and have less power. Just run reg if your car calls for it.
As far as running 87 in a car that requires 92.....on my 05 SRT4 Neon (230 hp 2.4 turbo bone stock) I WAS running 87 when I first got it. On my 80 mile loop that I use for mpg comparisons I got only 27 at 55-60mph while it was rated at 31. I even fill up at the same pump and put it on slow speed till it clicks off...not a penny more...then with 92 oct I then got the 31. That car now gets 32.8 with a stage 3 set up that developes 285 hp!
As far as 10% ethenol is concerned.....you might get as bad as 20% WORSE mpg since more fuel is needed to obtain the same driving parimeters. I read in a magazine last year that E85 can be as bad as 27% worse than straight gas and on my flex fuel 01 Caravan it did get @ 25% worse on E85 compared back to back with reg 87 oct gas.
Guys that convert their drag race cars to alcohol must increase the jetting in their carbs by about double for the same power levels, but then they benefit from a cooler running motor and can mofify them to run more compression and or boost.
42 time NHRA/IHRA drag race champ
05 SRT4-12.17@117 mph on DOTs-31.0 mpg-SOLD
96 Geo Metro-3 banger-60.1 mpg-SOLD
95 BMW M3-13.41 @ 106 mph-31mpg-SOLD
77 Chevy Monza with 350/350-FOR SALE
84 Horizon-1880 lbs-29 mpg
95 Neon-43 mpg
99 Z28-10.80 @ 127 mph-27.1mpg
2011 Prius-62.1 wife's
