Old 07-28-2008, 06:18 PM   #10 (permalink)
CobraBall
CobraBall's Avatar
Regarding Smooth Hubcaps- They are made by mooneyes usa. Gto:
https://www.mooneyesusa.com/Store/pr...b5efe351d72fdb Before I would spend the $$, I would do a cost/benefit analysis. The car may not last long enough to pay hubcaps.
50 PSI on 44 PSI tires. IMHO what you might save in MPG by overinflating the tires will be lost when the center of the tires wear out prematurely .
Overinflating also decreases the tire contact area making the vehicle more likely to hydroplane on a wet surface. Not a problem if you live in Mojave.
On the other hand the yellow calipers will be good for at least 2+MPG increase .
