Originally Posted by Joris
Maybe it could work if you let all the air out before welding. And welding small taps on the rim is not going to generate that much heat.
esp if cooled between beads.
in the video: due to the amount of smoke present, it would be safe to say there was a flame inside. was it flammable, such as fix-a-flat? temps rose steadily until destruction so it appears this was a rigged experiment and was for a specific reason. was the bead welded directly?
and finally, where can I get a robot welder?
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
