06-28-2015, 10:24 AM
Not banned yet
getto - '02 Volkswagen Jetta GLS TDI 90 day: 53.82 mpg (US)
Originally Posted by Xist
.....Can I bypass the wireless setup and run a wire from the fuse box to the shutters?..........
I read all over the whole page, watched video and saw nowhere that mentioned wireless.
there is this:
"Removable timer module for easy programming and battery installation"
is yours diff than the one linked?
one review:
"It works, and the best of all, it is amazing platform to make your own mods! Just get this, and an arduino, and you can connect it to a smarthome!"
another:"I don't have one of these but believe it's a great idea and wanted to expand on the whole concept. First, as far as I've seen there's this one and the Activent; both do the same thing with the exception of the Activent having a remote control. However, it’s much more expensive at $60 per vent...."
finally:
"This thing is pretty awesome. Either standalone (you can set times it opens and closes) or working with an arduino A/C controller project. Very hackable if you're into that. If not, it's a great standalone product too!"
FOR SALE: 02 TDI Jetta- 5 sp: Cooper CS5 at 50 psi, UltraGauge, ventectomy, rear air shocks, mufflerectomy, LED plate light, upper fiberglass grille block, front lower pan, front fairing.
93 Chevy CrewCab 6.5 TurboDiesel, GearVendor OverDrive, 4L80 w/ TCI controls. Now DailyDriver
