Old 06-30-2015, 07:54 AM   #72 (permalink)
GreenHornet
GreenHornet's Avatar
I found a pretty solid candidate as my heater replacement along with all the louvers and fittings I will need. This unit is pretty efficient as it only uses 3 amps at start up and 2 amps continuous. The heater is extremely compact and lightweight at only 2.5lbs. This will be more than adequate at 3.5kw to heat the cabin as well as handle defrosting. This unit will also allow me to bring in fresh air to the cabin via the existing duct along the middle of the upper hood area. I will have no problems hooking this guy up under the dash and getting to it later if need be.
Name:	3.5kw Heater #1.jpg
ID:	18174   Click image for larger version
Name:	3.5kw Heater #2.jpg
ID:	18175   Click image for larger version
ID:	18176   Click image for larger version
Name:	Dash Vents #1.jpg
ID:	18179   Click image for larger version
Name:	Dash Vents #2.jpg
Name:	Dash Vents #3.jpg
