I read on another forum that the 2nd gen insights have about a 900lb load limit, not including the drivers. I'd logic that I should be able to do a few hundred lbs for an extension, then
That's a stretched G1 in the pic, rated for about 350 lb including the driver
Long as you didn't have to get in it, you'd be okay
