Old 07-28-2008, 08:54 PM   #2 (permalink)
pasadena_commut
Originally Posted by trikkonceptz View Post
Can we create lift by modding the underside of our vehicle? Not enough lift to flip us over, but enough lift that at certain speeds could affect the engine load thereby making our drive more efficient?
I don't think there is a practical solution for reducing rolling resistance through lift. In order to generate enough lift with some type of wing to make a difference the car will have to be going pretty fast - by which point aerodynamic drag should be a bigger factor than rolling resistance. Hang your car from a streamlined helium blimp and you can maybe have a win at around 10 mph - if there's no wind. Surround your car with a hovercraft skirt and add a big blower and you can reduce rolling resistance to almost nothing, but again, not very practical since you have to use a lot of energy to maintain the pressure under the car.
