Old 07-03-2015, 10:06 AM   #12 (permalink)
iveyjh
iveyjh's Avatar
none - '98 Honda Civic HX
none - '00 Chevy (Geo) Metro base
none - '00 Saturn SL1 base
degree per tooth
For consideration: 40 teeth on a stock 1998 Metro/Suzukiclone G10 1.0L SOCH cam sprocket = 9 degrees per tooth.
You have to double that because of the 2 to 1 ratio cam to crankshaft, makes 1 tooth effectively 18 degrees.
The Following 3 Users Say Thank You to iveyjh For This Useful Post:
2000mc (07-03-2015), Daox (07-03-2015), MetroMPG (07-03-2015)
