Old 07-04-2015, 01:38 PM   #2 (permalink)
user removed
If your cam sprocket has 36 teeth then one tooth off is 20 degrees. (two revolutions of the crank per rev of the cam). The cam sprocket would have to have 72 teeth to have 10 degree changes moving 1 tooth since the camsprocket would rotate only 180 degrees for each revolution of the crank.
regards
mech
