Old 07-04-2015, 08:18 PM   #86 (permalink)
cRiPpLe_rOoStEr
Could you use AC to just dehumidify the air and then use a swamp cooler?
Some slaughterhouses and butcheries use this trick to reduce the weight loss of the meat, and it also decreases the energy output required to lower the temperature because of the higher thermal conductibility of the water compared to dry air.
