Originally Posted by cRiPpLe_rOoStEr
And then, someone would push for enclosed trikes to also feature crumple zones, airbags, whatever, thus eliminating their advantages regarding weight and the design freedom which even enables some more accurate aerodynamics...
Exactly, they could build a new 4 wheel simple geo metro type car but then it has to have the laundry list of stuff required in a new US spec car. I'm amazed that the Mirage can be had new for just a tough over $11,000. You strip all the saftey and most of the emissions stuff and it would be pushing the 70 mpg if tested the Elio probably is and be under $8000. I bet the MPH claims Elio is throwing out are not a regular EPA automotive test.
