Old 07-06-2015, 05:02 AM   #5 (permalink)
markweatherill
Send a message via MSN to markweatherill
What I've used is household G4 bulb LED replacements that are disc shaped. There is room for them inside the interior light lens, the wires are easily attached to the copper tracks* inside the light fitting, and they are certainly bright enough.
*once you figure out which track is which
...you could also wire a beeper to sound when the interior light is on and the ignition / accessory position is off.
The Following User Says Thank You to markweatherill For This Useful Post:
Xist (07-06-2015)
