Originally Posted by MetroMPG
If you're actually trying to slow down, leaving it in gear will save a tiny bit more fuel, as the injectors go into fuel cut when you release the accelerator above a certain RPM.
Good to know, maybe I had better read over those instructions again to be sure that I understood things correctly.
