Old 07-09-2015, 03:39 PM   #20 (permalink)
cRiPpLe_rOoStEr
If the natural humidity is low just leave a bucket with tap water inside, far cheaper than buying distilled water.
I'd imagine they'd have a 'low water' light. If you run out of water, they'd really have to retard timing I would think to avoid knock.
Retard ignition timing, increase the intake valve timing to lower the dynamic compression ratio (a VVT miracle), sure they know how to overcome it.
I honestly can't see the A/C system providing that much water, but I could be wrong. Also, that fuel efficiency increase is really going to take a hard hit if you have to use the A/C to refill the water supply.
What if it had an all-electric A/C, like the Prius?
