My chrome steel wheels are starting to rust, so I'm getting closer to just drilling them to use the swap-meet MOON disks I have. I'll need 24 sheet aluminum 1" disks bent double to repair the disks.
What I intend, if and when, is to drill oversized holes and use neoprene washers and pan head screws to try to absorb the movement.
can you post a pic of the moons you have? sounds like they were used for templates somewhere. i might have a fix because i have extra aluminum laying around.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
