Originally Posted by ThePrudentNinja
So my question is, is it even possible for a gasoline fueled internal combustion engine to be used to produce steam in any way that would actually be efficient?
Waste heat recovery ... about ~2/3 of most the gasoline fuel's chemical energy is thrown away via radiator and exhaust heat ... Although a steam version will most likely be less net efficient than other waste heat recovery options/methods ... it would satisfy what you asked for.
