Originally Posted by aerohead
There is a factor called 'curve resistance' ..........
well thank you. you just confirmed what Joris said.
hopefully i can see a change on the straight roads. will be in it tomorrow and did finish the right side also.
there won't be an A-B-A, just A-B because i won't remove them unless they make it worse or there is no improvement.
if they work, i want to smooth them out to make some molds. never done that and would be a fun and learning project.
