Old 07-10-2015, 06:13 PM   #35 (permalink)
deejaaa
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
(1)Short of going to the weld-on Dzus fastener system,an adapter might be fabricated which was captured under the lug nuts which provided a hard attachment point(s) for the MOONs.
(2)Even a single central fastener might prevent the cover from beginning to displace outward.Don't know.
(1)Dzus wouldn't work. these are stainless with the attachment crimped to the underside. holes would need to be punched through the stainless after removing the attachment device.
(2)thought about this also. welded nut to middle of rim with some way of centering it. a round head long thread stainless screw mounted with blue locktite........
sounds complicated....
i don't know either, reason i went with wire. next will be elastic cords.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
The Following User Says Thank You to deejaaa For This Useful Post:
aerohead (07-11-2015)
