I'm reluctant to switch to LEDs if the config isn't strictly legal.
ECU is currently on my desk with a wire running from the injector pin.
Word of advice: Only resort to tapping at the ECU if you cannot deal with having to replace the harness since it is hard to make a good connection (I put my 50k resistor for the MPGuino's injector monitoring inside of the ECU so that if the wire shorts to ground somewhere, it won't cause half the injectors to stick open).
EDIT: ECU back in car. I'll put radio back in later. In other news, my car goes FULL BMW when I unhook the hazards button (I lose blinkers).
I need to tap the VSS and power now.
