Old 07-29-2008, 05:13 AM   #1 (permalink)
Vince-HX
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 honda civic Hx
Last 3: 58.02 mpg (US)
Turbo normalizing for cars?
So I have to admit it, I love/live turbos. And I have been thinking of the most ideal application of a turbocharger for maximum FE.
One thing that really caught my eye was turbo normalizers for airplanes.
"A stroke of GENIUS – turbo-normalizing technology. Traditional turbocharging boosts air pressure as high as 40 inches of manifold pressure, creating higher induction pressures and temperatures than a normally aspirated engine.The turbo-normalizing approach, however, only allows the air pressure to build to a normal 30 inches of sea level pressure. Even at 25,000 ft, the engine thinks and performs as if it's flying at sea level. The engine can do this at lower induction air temperatures and lower manifold pressures than traditional turbochargers – all using the inherently more efficient cylinder compression ratios found in normally aspirated engines."
I know that the situation is quite a bit different with cars because we don't see the massive elevation changes.
My main theory is that boosting to one atmosphere (0 on a boost gauge) could help with reducing pumping losses.
A highly efficient small framed twin scroll turbo and response tuned individual runner manifold would be used. I think with this combination I should be able to have less back pressure than the stock exhaust and any reversion between cylinders should be eliminated.
I have already approached a well respected tuner and he assured me if the manifold air pressure never went positive the stock ECU should be able to handle everything just fine (MAP car). Read - OBDII can stay OBDII
Could be a really interesting experiment. Either way My Y5 will be breathing in compressor churned air. If it doesn't have a noticeable effect I will be converting over to OBDI and completely retuning with a ported and polished Z1 head (11.8-1 compression), then if those results don't show much improvement the y5 head will be going back on and the engine will be tuned for moderate boost.
I would love to hear your guy's thoughts
And I have plenty of weird and crazy ideas where that one came from
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
