Old 07-14-2015, 09:39 PM   #43 (permalink)
deejaaa
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
Originally Posted by mememe View Post
For better fuel economy, you need a tire that changes pressure the least during temperature changes. (run with a TPMS, run a CTIS and there won't be any worries) When you fill your tire up cold compared to after driving, the psi changes. (what if you fill up AFTER driving? will there be much change?)
You will need a gas that conducts heat the least. A gas that is dense so it will leak out of the tire the least over time. (why use gas? use a dense liquid, like water.) A nobel gas that doesn't react to the remaining air in the tire and doesn't react to the chemicals in the tire.
Since it is probably not a good idea to fill your tires with Radon, the next best choice would be to fill your tires with XENON.
Thermal Conductivity of gases comparison:
Helium___0.142 (W/(m·K)
Neon____0.046 (W/(m·K)
Nitrogen__0.024 (W/(m·K)
Argon ___0.016 (W/(m·K)
Krypton__0.0088 (W/(m·K)
Xenon____0.0051 (W/(m·K)
Radon____0.0033 (W/(m·K)
Density of gases comparison:
Helium____0.1786 g/L
Neon_____0.9002 g/L
Nitrogen__1.251 g/L
Argon____1.7818 g/L
Krypton___3.708 g/L
Xenon____5.851 g/L
Radon____9.97 g/L
So please fill your tires with xenon and tell me how it goes. (i would like YOU to fill yours first. let us know how much it cost and then how much it saved in fuel. compare the two and state how logical it was.)
But if you want your gas to be very dense, denser than Xenon so it doesn't leak out and you want to do the opposite by conducting heat more rapidly than Helium, why don't you try Sulfur hexafluoride.
Thermal Conductivity of 0.0121 (W/(m·K) and density of 6.17 g/L
Fill one tire on your vehicle with xenon. Fill a second tire on you vehicle with sulfur hexafluoride. Drive for a while. Measure the tire pressures after driving. Compare the difference.(still don't see the logic. pressures will change, just by checking pressures.)
nice 1st post.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
