Old 07-29-2008, 07:26 AM   #15 (permalink)
ajax_6531
1997 Civic POS - '97 Honda Civic EX
90 day: 33.29 mpg (US)
Send a message via AIM to ajax_6531 Send a message via Yahoo to ajax_6531
How about a weave of large diameter tubing spread throughout your yard underground? As the water flows, the greater surface area of contact between the tubing and the outside would be more efficient in heat transfer. You can use whatever you want without the worry of freezing as long as it's buried below the frost line. Be sure to insulate anything above the frost line and in the air.
IYAOYAS
