Thread: EV build aero.
Old 07-15-2015, 11:52 AM   #27 (permalink)
freebeard
Keep in mind what The Template looks like in cross-section—a half circle that is twice as wide as it is tall. The slope assumes both sides taper as much as the top
The rear edge of the cab is basically a rectangle that is as wide as it is tall. Since there is twice as much taper in the sides, you wind up with a vertical trailing edge.
These are full bodies, instead of half-bodies; but include the squircle, half-way between the square and the circle:
aerohead (07-15-2015)
