I see you are using royal purple motor oil in your MT, how is this working for you? I will be changing my MT fluid soon, and I want to use whatever is best for these vehicles. So many choices.. Honda MTF, Red line MT90, Penzoil synchromesh, Royal Purple synchromesh or motor oil. The book says to use Honda MTF, obviously, but it does say you can use a motor oil as a temporary fix until you can get the right stuff.
Also, what spark plugs are you using? The book says NGK with a number 5 in there, and others are saying the correct plug has a no. 4?
