Thanks for you detailed list of Mods, this is an awesome response that will be immensely valuable. I need to get out to my garage and get to work.
From What I have read, lowering the vehicle reduces the size of the hole that it punches through the air so you should benefit in reduced frontal area. NASCAR takes this to the extreme of the rules. They also believe that stopping air from moving under the car at all is beneficial and try to duct it around the vehicle as much as they can. The Honda' benefit from a very nicely sloped front end which eases the airflow over the vehicle.
