Old 07-19-2015, 01:43 AM   #2 (permalink)
some_other_dave
#1: Use thin metal wires and run current through them. They'll dissociate the H2 from the O in the water and make bubbles, which will travel with the water.
#2: Invert the model, and make the top of the tunnel the ground. Gravity will keep the water from leaking out any holes in the top.
Make sure you keep open flames away, though.
-soD
