Old 07-20-2015, 06:35 PM   #2 (permalink)
aerohead
Naked vs Aerolid-RV
I roughed out some numbers for the comparison using a 12% allowance for the air density,BSFC 0.537,and R-R from the Caterpillar article based upon the test weights and given speed.
*The naked F-150/Apex combination comes in at Cd 0.600 for the rig,based upon the frontal area of APEX.
* Drag factor of 37.2 sq-ft.
*The EcoBoost behaves as if the F-150 has Cd 1.03.
*The F-150 Aerolid-RV/APEX combination is Cd 0.506.
*Drag factor of 31.372-sq-ft.
*The EcoBoost behaves as if the F-150 is Cd 0.87.
*The Aerolid-RV setup provides a 15.6% CdA reduction.
Going after the vertical edges of APEX,it's gap,rooftop AC unit, tail,and maybe the belly, should line 3-Cherries up for a big jackpot at the gas pump.
BamZipPow (07-20-2015)
