Originally Posted by darcane
Most of the airflow into the radiator should come through the opening in the bumper cover. Unless there is a power steering cooler or something up top that you are trying to get air to, I would just block the entire upper.
Also, I tried to do a similar block behind the grill on my old Silverado. I believe the air pressure pushed on it and flowed around the block anyways. It was far more effective in front of the grill than behind.
The upper grille is right over the radiator, the lower grille is fully blocked because it didn't give much to the radiator.
I don't plan on going to a front grille block if I don't need to, I like this look better
